(quoted from post at 11:53:39 11/26/20) I drove thru the chevy lot this morning and saw this on the window sticker.
(quoted from post at 09:04:57 11/26/20)(quoted from post at 11:53:39 11/26/20) I drove thru the chevy lot this morning and saw this on the window sticker.
GM is just trying to catch up with Ford.
Again
You mean colorado or canyon. Sierra is the gmc silverado(quoted from post at 15:24:50 11/26/20) Read all previous posts.
As previously posted, probably a Canyon or GMC sierra with 4 cylinder 4 cycle diesel.
If Chevrolet, GMC, or anyone else offered a LT with a 4-53 (or even 3-53) Detroit, I would buy one in a heartbeat.
Dean
(quoted from post at 16:24:22 11/26/20) You absolutely can make a smaller engine and say it will get better fuel economy.
If you look at an efficiency map of the engine, large naturally aspirated engines operate pretty far off the sweet spot under light load of normal driving. Smaller the engine the closer you can get to the lowest brake specific fuel consumption.
This is principal behind the cylinder deactivation on the various v-8's, they improve the engine efficiency at low hp requirements by increasing the operating pressures/temperatures in the remaining cylinders. Even while suffering the friction
loss of spinning 4 dead cylinders around it still improves efficiency.
(quoted from post at 18:26:44 11/26/20)(quoted from post at 16:24:22 11/26/20) You absolutely can make a smaller engine and say it will get better fuel economy.
I may of not made that clear. All gains are from less friction and to a certain extent higher combustion pressure. But a truck in a headwind will use pretty much the same fuel.
(quoted from post at 17:32:21 11/26/20)(quoted from post at 18:26:44 11/26/20)(quoted from post at 16:24:22 11/26/20) You absolutely can make a smaller engine and say it will get better fuel economy.
Less friction??
How about a more complete burn in order to get as much work out of the btu's contained in a unit of fuel?
Fuel injection, computerized engine management, etc. etc. has made massive improvements in hp, torque and fuel economy.I
As well as automatic transmission technology and with more than double the gears than the engine bolted to them.
Are you too young to remember driving behind a carburated car/truck and being gassed from all the unburned, wasted gasoline?
(quoted from post at 12:43:47 11/26/20) Rumor mill has it 2021 will have a turbo charged V6 as an option rated at 325.
(quoted from post at 09:41:43 11/27/20) I find the comments on here about turbo's never working on gasser's entertaining, while they are fine with turbo's on Diesel's. This technology has been on gasser's in Europe for more than 20 years. The days of big displacement are gone, technology is allowing smaller engines to produce the HP and torque needed.
