grandpa Love
On a tractor with an alternator you can pop the battery cable off and if alternator is charging the tractor stays running. I know you shouldn't.....but..... My question is does a 6 volt generator work the same way?
hat is not universal....it depends on which alt and even within the 10SI family, which VR is installed. Blanket one size fits all statements are almost never accurate.(quoted from post at 12:13:12 11/12/20) Yes that will work.
But pulling a battery cable off when you have an alternator can also kill you if you get your self in to it in such a way the current goes threw you. When you pull the cable off the V.R. sees a dead battery and put out max amp and max volts and can put out more then 90 volts and more the 35 amp which is enough to kill you
