(quoted from post at 21:16:20 11/11/20) Just replace the distributor with a HEI. 1 wire hook up,new wires and plugs will be needed.
doubt switching from HEI to a points distributor would have much effect, but if you do make sure you have the proper incoming voltage to the hot side of the coil. An HEI would have full voltage whereas a points system would likely have some sort of resistor, either with a ballast resistor or a steel wire coming from the ignition switch. Sticking a points distributor in a vehicle that came with HEI would cause the points to burn up very quickly.(quoted from post at 06:59:31 11/12/20) I would like to chime in with a question on Chev engine also.
Our chevy 350 in a p 30 van body modification to factory R.V. creca., 1983 has an electronic distributer; with maybe 10 to 12 mpg >>Thinking of converting it back to points distributer [ new off shelf designed for 1973 350 Chev] and re fitting the carb with leaner jets. All for hoping to reach 20 mpg. Would one of you mind writing me directly so we may discuss this via e mail.
Thank you.
Wm.
(quoted from post at 23:10:09 11/13/20) 😀😀. I suppose I could cut the motor off and make it a dump trailer
