Well, one nut, anyway, and it's driving me nuts. I was disking the other day with a Massey Ferguson 3 point disk, Model 39 if I read the corroded tag properly. Well, the nut on the axle came off, and I lost the nut, about 3 washers, a 4" washer, a disk blade, spool and damaged a second disk blade. Somewhere in a 3 acre field. Have a couple blades, some washers, and a nut in stock. The spool is on order from Shoop (they don't give those things away.) The shaft is an inch in diameter, and I have a couple nuts which thread on to it. Problem is, what wrench do I use? Nothing I have fits it. Took the nut to Harbor freight, and Menards. Closest I can come is a 1 1/2" combination box end/open end wrench. But that is quite loose on the nut. Next smaller was too small. Tried Metric, and no luck there either. So I got out my handy-dandy digital caliper. Read across the flats, 37.18mm but a 37mm wrench wont fit. No 38 mm wrenches available, would be loose if they did. Read across the flats, 1.460inches. Anything less than 1 1/2 inch wont fit and that one is very loose. Read across the flats 1 59/128 inches. Who ever heard of a wrench that size?
Looking for a 4" washer with 1 inch hole, about 1/4" thick.
