Farmall H Magneto What am i doing wrong
FWB in SK
I wanted some imfo on the Farmall H magneto. Went to modern view search Typed in Farmall H magneto in the Farmall Forum search. Got every thing else but nothing about magnetos..
The tractor I have is A 1944. Were all H mags the same through out the H span etc..Need some parts . Have some manuals.
yes basically the same h4 mag on all tractors. even the lb stationary engines use the same mag. diesels and w9 gas have opposite rotations of gas engines and its counter clock wise.
Search for what you did not say what parts you need i have some parts mags they are the same used for many yrs on all the I-H tractors
For search you have to click on "modern view." Then there will be a box that appears on the upper right side of the screen. Click on the word "search" in this box. Then a new screen appears, with the option to search different forums. I suggest searching for "farmall magneto" or "h4 magneto." Be sure to click the little circle below the word search box that says "search for all words." Otherwise it gives you a zillion responses with a lot of info you don't need.
Or, you can just post your question here. I am not an expert on magnetos but I rebuilt two just last year, so am happy to share anything I remember before it fades from my memory. I also have the h4 manual and will be happy to look up specs for you. Good luck, Dave
