elijahearnestfarmall
Evening gents,
Worked on the engine for the Huber today (the unit is a waukesha model N). Scraped the caked on oil, brushed with diesel, removed the oil pan and attempted to remove the gear on the water pump shaft. However, the darned thing refuses to budge. We used a puller + break-free-juice + heat, all at the same time, with no results. The puller ended up breaking a few teeth so we held off on the puller. Planning on just spraying it with PB blaster for a while.
On a better note, we went to mark the teeth on all the gears for timing references and actually found the original marks. I just find it amazing that someone was doing exactly what I was doing 100 years ago! Felt really connected to the tractor today lol.
If anybody has any suggestions or knows anybody that has worked on these engines, any pointers or directions are welcome.
