SVcummins
One hay field last night i would like to get one more spread
but I don’t know if my pocketbook will let me
This has a sprocket that you lower down and there is another sprocket that drives it off the ground wheel
Pto Runs the Flipper, Ground drive for the drag chain....
I know the Pocket book problem.. But sometimes you have to just have faith..
Last year I took a parcel that was 2.75 ton per acre/yr the last 2 years to 4.2 ton per acre/yr this year.
I’m going to try and figure out if i get enough for one more field and then the other field I’ll probably spray liquid on the other in the spring
