Nh TL 90 brakes leaking brake fluid
My neighbor has a TL 90 and it is leaking brake fluid can’t find where it is leaking I have heard this is a common problem with this size tractor, he wants me to look at it and see if I can fix it and I have never worked on this kind of tractor before can somebody help me out here
Does this tractor have a brake master cylinder that is not a part of the hydraulic system that needs to be manually filled with mineral oil brake fluid?
If that is true and there are no external leaks likely there's a leak in the brake piston area that's dumping mineral oil brake fluid into the rear end/hydraulic oil.
Just be sure to use the right fluid.
Pretty sure it takes mineral oil brake fluid, hopefully the neighbor didn't dump DOT3 in there.
Seen it done when the owners manual wasn't read.
Fred
hello I have done a few it the oring on the brake piston like wore out said not a bad job just have to pull the axles to fix
