(quoted from post at 02:21:29 11/07/20) Does this valve in the linked picture look like yours? If so I can only direct you how to connect it to your tractor by using one set of your SCVs (selective control valve) or implement auxiliary remotes. The valve port the elbow you see facing you is the hydraulic return, likely marked ..OUT. There is another port directly across from it that cannot be seen that is the hydraulic supply to the valve, likely marked ..IN. These two ports need connected to one set of hydraulic remote outlets on the tractor. The original hydraulic lever (SCV) for those remotes will need to be placed in the position that gives flow and pressure to the IN port and possibly held there with a bungee while using the loader. The other ports coming out of the top of the valve go to the cylinders on you loader. The function pairs that connect to the same cylinder are in line above the valve spools ..part that slides in and out when lever is moved.. I don t know if you can follow this by description. I have found a generic diagram I will add a link to In another reply. There may be a way to plumb this valve to your tractor without using auxiliary remotes, but someone more familiar with your tractor will need to explain that.
Hyd valve
