IHdigemdepper
New User
I have a 66 IH Industrial loader/backhoe & after changing motor oil & sitting for 3 weeks the clutch would not disengage trans.Everything is working from pedal through throw-out bearing & when starter is removed you can see fingers of clutch releasing.My tractor doesn't have a TA set up just 5 forward gears & a reverser.I have been in the auto repair business for over 40 years & have seen clutch discs rust to the flywheel or to the trans input shaft & made disengagement very difficult or would not disengage at all but looking through bottom inspection hole all looks VG..no rust on splines & everything working as it is suppose to from what I can see.I have also sprayed a can of penetrating oil onto clutch soaking it over a few weeks just to see any difference.No change.Once in gear tractor will spin tires & dig dirt if held in place with no clutch slippage even when clutch is disengaged with clutch pedal.Am I missing something??? Any help would be much appreciated.
