I am having problems with the 3pt not lifting and the hydrolics. If the tractor runs for 15 minutes to 1/2hour they "awake" and work great. I was told that there is an air leak in the sucker pipe but can't see any sign of it. This is a 1969 Ford 3000 I changed the hyd filter and the oil a couple years ago. I saw a forum on "flow control valve 2012" that discribed my problem well but they never gave a final solution. When the hydrolics 3pt work they sometimes are jerky. I had the whole top off the rear axle, incudes the 3pt arms and hydrolic remote lever and it all looked fine. I put back together siliconed for gasket and nothing changed. What do I check for next. chesty
