Finished discing
SVcummins
Finally finished discing about 1030 then took a trip to pick up my triticale seed . Going to bring the tractor disc and roller home tomorrow get unhooked get the lely on and go mellow out some big clods hopefully drill tomorrow but i may not quite make it. Also planning to get the loader off the 4020 anr get it hooked to the two way plow so it can head south to start plowing next week
Blew a hydraulic line someone had replaced the original with copper tubing and the line clamp wore a hole through it a 3/16 brake line makes a nice replacement the number 2 jic fittings fit the brake line just right . Worst part was losing 7 gallon of hydraulic oil
Nice Work! sounds like things are moving along,, we are finally getting some H20, actually wet outside now and they say more on the way for a day or so off and on,, I ripped part of a field last night hoping to for this to happen,, but got a late start so only about 20 acres worked, no matter it will help as this filed is on a hillside and likes to let it run off unless I do this, and we had been feeding cows on it the last month and a half, they had made two trails right where it like to wash and this will slow that down a lot
cnt
Ah yes...
When will you be off work???
When I get home from work!
ok when will that be??
When i get home...
Its an endless cycle.. they don't understand..
Looks good glad you are getting some rain we still have not seen more than just a few drops. Are you feeding hay this time of year?
