MF 1100 Diesel radiator?
Tazzerblue
New User
I've purchased a New replacement radiator for my 1100 Diesel. I will try and post pictures. My question is the replacement has a longer neck on the bottom will that be an issue? The one I removed had an MF part number on the top, but I have No clue if it is original. It looks like all the New repalcements come with the oil cooler bung's. I guess you just plug them.
The 1130 used the oil cooler, the 1100 did not so just plug those two holes. If I recall dad's late 1100 had a longer lower outlet too, but tractor is not close by to check again.
Rarely are aftermarket radiators exactly the same.
They try to make one that will fit several applications.
Sometimes they fit, sometimes you have to make modifications.
I wouldn't get too carried away modifying, or do anything you can't easily undo.
If it won't fit, send it back, order a different brand and hope for the best.
And keep the old one, just in case...
