Massey Ferguson 135 wheels
B.Real
New User
my massey ferguson 135 has spin out wheels on it witch I do not use. I need to replace the rims due to rusting out. Do I have to put spin out wheels back on or will some other wheel bolt to my wheel centers. Thanks
If the centers are designed for spin out rail wheels, that's the wheel type you need to fit the centers. Four rail wheels are available, or if you can find a manual
wheel/rim pair from an older 20, 30, 35, or 8N ford wheels will fit also.
I had the same problem on a 245 a few years ago. The rail clamp bolts were rusted pretty bad and I had to remove the four rim bolts to get the new one on. I used the Massey tool that came with my dad's 50 to try and remove the clamp bolts and promptly broke one off:-( If yours are not rusted badly you might get by. I bought mine from hayspear?.com, shop around, the prices vary a bit. Good Luck with it.
