JD 2555 mfwd hub disassembly
I’m trying to disassemble the front hub on my 2555 JD. Removed the wheel, hub, snap ring, washer, 8 bolts...but the ring gear is not budging... any suggestions ? I tried to put longer bolts in and push off the ring gear from the inner hub. I do not have a diagram or blueprint but if I’m looking at it correctly this method should work...? Any suggestions would help. I would rather not break anything and the bearings are in good shape. I just need to get at the faulty inner seal, thanks
John Deere manual says to install 3 10 x 80mm screws into the hub carrier, then place a disk on top of them as a support for a puller screw. Then attach a puller with arms on back side of ring gear. The ring gear is mounted on 8 bushings with loctite and will need warmed for removal
