Lost a bearing
SVcummins
The ihc 370 siezed a bearing about 430 am gave me enough time to sneak a quick nap and then got sent to purgatory again. Going to pull the harrow off and found a big roller to pull .
ya then all you have to do is plow snow, repair equipment and feed cows.. oh then feb comes and you get to baby sit those cows 24/7.. why do we do this stuff again???
Has a big piece of 20 inch pipe running through the center of the tires then a plug welded in each end slide a bunch of old truck tires on then a shaft through the center of the pipe and a pillow block bearing on each end this one you can fill with water
Started going back together only of the pipe spacers would come out of the bearing going to have to torch the bearings in half to get the other two apart
Had to dress the threads up for the nut i was able to clean them up enough to get the nut off with my die grinder but it took a little 3 cornred file work to get the new nut to thread back on
