DavidP,South Wales
Hello, is anyone familiar with the fuel system on a Kubota L5040 compact tractor? The engine dies suddenly. The main paper type filter (not spin-on) was blocked. It has been cleaned as much as possible whilst awaiting a new one. There is plenty of fuel reaching the lift pump but not coming from it so we suspect that perhaps the Ll has failed due to working against the blocked filter. It has already been replaced once. The engine is stopped by turning the ‘ignition’ key off so there must be a solenoid in the vicinity, but we cannot find anything which is vaguely cylindrical with wires attached to it. There is one wired item nearby but that is more of a sensor and in the timing casing. It does have key-controlled current going to it. Can anyone tell me where the solenoid is located? I have never seen a remote solenoid before. The only wired item near the pump is the one mentioned above .
Thanks in advance for your help.
DavidP, South Wales
DavidP, South Wales
