Super C lights
banjoman09
I bought a "Super C" and it is nice tractor; pervious owner converted it to "12V"... trying to find 12v sealed beam lights for this- anyone know a number please? If I knew a number maybe I can pick up locally. Thanks.
Take the old light with you to a Napa or other parts store. They will be able to cross it for you and provide a 12 volt light. I am not aware of a store-bought step for that tractor. However you can easily make something up if you have any welding skills. I have made up some steps on the back of my Super C. I attached it to the rear axle on the left side. You can attach it to the rear end housing, the fenders, the drawbar bracket, or just use your imagination. Not hard at all. I used rasp bars from a combine as the step. Use whatever you have on hand .
Are the outside shells on your lights missing also, or just the guts? If you have the outside, you should be able to measure it and determine what size you need.
If you need the whole unit, maybe try a place like Steiner's. Or else start visiting junkyards and swap meets.
Ok- I will build steps; the light metal frames are there and just need the sealed beam...just wondered on a number....thanks
For the old conventional lights they would be a 4411 for the sealed beam light. There is also another number for a spot in the 44xx numbers.
