Read postings
John-MI
Befrore the posting headings was I different color so you could see at a glance after read. Now they are all the same color print. Is this my I pad or a
change that was made.
It's a setting in your system. I'm not a Mac person, so can't tell you how to fix it. Look under settings in your Firefox or whatever else you use.
(quoted from post at 17:39:50 09/14/20) Befrore the posting headings was I different color so you could see at a glance after read. Now they are all the same color print. Is this my I pad or a
he Samsung browser on my Android does that. Hitting refresh corrects it.
My iPhone does that occasionally. The iPhone uses basically the same browser app ..Safari.. as the iPad. All I do is completely close the app and it fixes it. To close the app on a phone you go to the home screen and open the screen that shows all the apps you have open. On the phone you do it by swiping up on the screen from bottom to top. When the open apps are showing you just put your finger on the Safari app and swipe it off the screen. You don’t even have to close your tabs. I generally have 40 plus tabs open at any time. When you reopen your Safari all the tabs come back. When I go back to my YT tab everything I have read has changed colors. This may happen to me maybe once a month. If it happens to you daily or even a couple times a week there is probably a setting that needs changed. Also do you update the software on your iPad when it is available? That helps keeping things up to date.
I only use a lap top here,, some days it will change color some days not been doing that a week or two at least sure is nothing I did on my end
Just a thought. The times they are all the same color can you confirm you were logged in? Occasionally I get logged out and thats how I notice it.
