iso 1951 Case hydraulic pump
Jackson460
New User
I have been looking for a dual valve pump because the dc 4 I recently purchased has one that grenaded any help locating one would be greatly appreciated thanks
The dual valve or remote is so I can tip the loader bucket and operate the loader
The later models with eagle hitch and the larger tractors had two remotes, earlier models only had one.
Please correct me if I am wrong, but couldn't you mount a 2 spool or more valve on the tractor or loader frame, have a return back to the tractor set the hydraulic valve on the tractor to "lift" and you would
have the ability to raise the loader and tilt the bucket.
Year you can, but he said his is bad and if he has the two spool he will need that to run the eagle hitch. The eagle hitch spool isn't true two way and won't work well on a loader application.
