rick n ohio
I have a NH HM235 discmower 6ft 8in cut it has 5 turtle shells as you can see in the pics the three in the center cut almost two inches higher than the ones on each end the three in the center were pretty beat up from the previous owner the elongated holes were wollered out so I replaced the three turtle shells in the center with all new blades even on the outside two cost $850 dollars and it didn't change a thing still cuts two inches higher as you can see in the pics the turtle shells on each end look perfect can't see anything wrong with them they are taller than the three in the center they cost $800 each That's another $1600 I would be putting into it not counting the $850 I just put in it.so do I replace the outer two and take a chance it cuts correctly.i don't have a concrete slab to park it on to get a good look at it. It almost seems like it has a slight warp to it I'll try to string line it see what that says.whats your thoughts. Thanks Rick
