The problem: When I rev it up much past idle, I will lose all hydraulic functions, bucket, lift and motion. Back down to or near idle, everything works as it should. Manual says for hydraulic fluid use "Transmission Fluid Type F". Reservoir is at the full level.
Question: Could I be "foaming" the fluid when I rev it up? Have any of you experienced this on any of your machines, tractor or skid steer? What fluid should I be using?
We also have a Case 1816B that uses 10w40 for the hydraulic fluid, and it works perfect.
Thanks
Thanks
