SC mower again
Midway
I posted a few days ago about a finish mowers for a Super C with a work saver 3pt attachment. I located a 10 year old or so 6ft woods finish mower in good condition for about the same price as a new King Cutter mower. The woods is a little over 700lbs. Will the SC be able to pick it up? Would the woods be a better buy than the new King Cutter? I also have a MF 135 I would use on the mower I just wanted a mower I could use on both tractors. Both tractors are in good shape. I would appreciate any advice. Thanks.
I have used a 7 foot Bush Hog behind my SC,way under powered, but lifting it was not a problem. I also have a 8 foot disc that was a big point for a 300U,I cut the points down to the small FH on the SC. I did have a factory loader on it, so lets add 500# to the front but it pulls it and lifts it with the front on the ground. You will not have any trouble hook it up and start cutting. You will have a better cut if your mower has all 4 castor wheels on it,then you can just put it down and not have to carry it.
After owning a Woods for several years and King Kutters for about 27 years, I will take the King Kutter even if the price was higher.
Richard in NW SC
