Most everything was good when new, with a few exceptions. Will it fit your tractor? If it does, and was taken care of it should be worth that. Stan
bfullmer,
I have a Ford 501 sickle bar mower that is driven with a pitman shaft. It has a 6 foot long sickle bar. It works well, but over the years, I've had to do a fair bit of repair work and regular maintenance on it. Parts are still pretty well available. Do you know when it was last used? You need a manual to set it up if it's not actually working right now.
$300.00 is a good price if it's a good, working mower.
Tom in TN
Decided against sickle mower - looking for something to mow 2 ft under large pine trees any suggestions??
(quoted from post at 09:20:47 08/21/20) Decided against sickle mower - looking for something to mow 2 ft under large pine trees any suggestions??
A sickle bar mower is best for mowing under trees, unless you have the coin for a verge mower.
