In search of a G 176 continental engine block for a MF65
truckhtr
New User
Looking for a replacement engine block for a Massey Ferguson M65 with a continental engine G176A600 gasoline engine. Or a used running one mine has a cracked block.
There are several salvage yards in S. Missouri. Also, You might check with Kough Equipment in Farmington, Ky. Internet is your friend.
Depends where the crack is if block really needs replaced, if only at top between cylinders those usually won't hurt a thing. If LOWER sleeve area is cracked block is junk..
Not sure I know cracks in top but don`t know further than that haven`t tore down. Just hoping to find a known good block before going to that extent.
Been searching with no luck on either finding these salvage yards or a block. Do you have any links because so far the internet has not been my friend in this search.
