clock style hr. meter.
rustred
how many hrs. on this unit? off my 44 special.
ok think i got it. thanks. kind of a shame as tractor looks good but engine sure is a mess from exhaust pipe being broken. hope i can salvage it.
and here it is. maybe i can soak these pistons over night and they will pop out.lol.
took me a couple hrs to get the head off after i was ready to lift it. was seized on the studs. and talking about never seize humm.
My 44 was just as bad. New sleeves and pistons fixed her up just fine.
Needed the middle two valves. They tend to get too hot compared to the others.
Years ago I was given a MF with a Perkins diesel. It had a cylinder like the one without a hole in the block. I pounded out the piston. Honed it a lot still had pits. I put a set of rings on all the pistons. It has run for a lot of hours mowing, and will still run, if needed. I would do things different today.Stan
I had a 55 seized like that. The block was cracked between the two rusted cylinders and was not repairable. Hope yours is OK.
Ben
i do have a spare set of used pistons and sleeves from my uncles 44 i replaced when i was 17 years old. he wanted new pistons and sleeves so i kept the old ones all these years.i also have his massey too. makes 4 specials i have. i will try to get these sleeves out and go from there once i get back to it. hope the block is good. a winter project now. i sure like the looks of them .i used to drive his special when i was 8-9 years old when loading bundles for the thrashing machine. lots of times we used his massey to run the thrashing machine. in the 1960's.
