Re: Considering purchasing Deere 4020 - High gears not work
tomstractorsandtoys
If it does not have 6 and 8 it is not syncros it is the gear on the bottom shaft in the trans. To fix you have to split,pull both rear axles,remove the pinion and empty the trans case. But if you can live without those gears it is fine to use it as it is. Tom
