super99
I bought a Bush Hog 3 pt cutter to use behind the Oliver 550. The tractor end of the pto shaft has been busted and someone welded it back together but they didn’t get it lined up right. The knuckle was about 1/2 off from lining the knuckles up. I ground the weld off and turned it to line them up and welded it back together. The shield came with it, but the clip that holds the guard on is missing. Are they a standard size or did different companies use different sizes? Can I get one anywhere or do I have to go to a Bush Hog dealer? I’ve been to the local John Deere dealer for simple things before and the kid at the parts counter can’t find anything without looking it up by the model number on the computer. Thanks, Chris
