Dave H (MI)
Started fine earlier in the month but would stall after 10 seconds or so. Then would not start at all. So I checked and adjusted the plugs. Has good spark. Replaced the fuel filter. Everything points to the carb so I pulled the air intake off and some gas spilled out. I drained the carb down a bit, sprayed some starter fluid in it and it fired to life. Ran about 10 seconds and stalled and spit gas out the air intake. This engine has a fuel pump, not gravity fed and I have little know how about these. It's a weird carb. Shine a light in the air intake and you can see the butterfly for the throttle. Doesn't look like there is anything in there. Did not pull carb pending responses here. Pics of engine and carb attached. It's a great starter but not sure why it is flooding so bad. Any ideas?
