Anyone recognize these old Allis parts?
Will Herring
I was digging around in the shed looking for something and ran across the one belt pulley I've got, and found this other assortment of parts, could be WC, WD, or cultivator or combine or I'm not sure what. I recognize the belt pulley my foot is on, and the brake plate cover for a WD in the middle of the picture. Otherwise, I'm not sure what I'm looking at.
Just above the belt pulley is a WD muffler bracket. That's a precious item as it looks to be in good shape, and they haven't been available for years. Then an air cleaner cap. Then what looks like a short piece of PTO shaft, with the special drive bolt.
I think you might have pieces there from all the machines you mentioned!
The rod under the shoe is a depth rod for the rear gang of a cultivator on a WD. The piece with the one hole in it laying on the
belt I think goes on the back land slide if a AC plow.
the sheetmetal part under the hose with two holes, one top and one bottom looks like a brake housing cover for a WD or 45.
Thanks for the feedback guys. Good to know about the muffler bracket, I will be sure to hang on to all this stuff, but especially that piece. Oh, and the cultivator lift piece, and the plow piece(s). I'm hoping to get back out to the shed in a day or two and clean up some more, and hopefully take some better pictures. Stay tuned!
The flat plate on the far right, bolts on the frame sides , and receives part of
a 2 row cultivator.
Ah yes, that does look sort of cultivator-ish... I suspect I've found some more of those type of parts today, too.
As promised, here is a better set of pictures of the stuff, and a few more items I found while cleaning up today. Maybe a few more items that people may recognize, now that stuff is separated out a bit.
