What tires fit on a stock Farmall super c rims
Dave I think you are right that the the 11.2/36s are you hat is supposed to be on there.
Jail-sd I know somebody that has a set for sale will I have to get different tubes?
12.4x36 on mine.
Gab, you tractor looks beautiful I really like thoughs 12.4x36s on it I think that is the tire size I am going to go with. My 51 super c doesn't look nearly as good but it dose what I need it to do (which isn't much)
If your existing tubes are in good shape,
they will work with 12.4's, they are not
that much larger internally than 11.2's.
Tubes usually fit several different sized
tires.
The 36" tractor tire class has limited sizes available. 11.2x36 are the most common because of the C and Super C. You should have no trouble finding this size. 12.4x36 are also out there, but less common and more expensive if you're looking at new.
There used to be a 13.6x36 as well but I don't think anyone makes them anymore. They were only used for a short time on a couple of tractors.
(quoted from post at 03:48:18 08/03/20) The tires you have now look like they will last a lot longer. Do they hold air ok?
When this picture was taken the tires held air fine but since the picture was taken one of the rips in the tire has widened and stuff has got in and popped the tube
[video play=false:a722927246]https://forums.yesterdaystractors.com/videos/mvvideo59610.mov[/video:a722927246]
