jtc
on the jub, i push the starter switch and nothing push the solenoid bottom push button and she starter. starter switch or key switch/ thanks
Remove the wire from the starter button and touch it to ground. BE 1000% sure it out of gear. If it spins over then the starter button is bad if it doesn't then you have a bad wire or bad solenoid
