Must be Monday!
kcm.MN
Location
NW Minnesota
puzzle: https://jigex.com/afSy
Where’s the air intake on that machine? Not good if it can’t run to help in getting it out!did something similar with a D-9 cat once but the water wasn’t up to the intake.
Been there done that.
If you have not done this in my area you have not been operating equipment very long.
Around here the biggest dozer you see is a D6 unless it is a controlled environment like a petcoke refinery.
Anything bigger than a D6 is to heavy and will not stand up on our soil.
Exactly my thought, after he gets the big cable hooked up to an appropriate spot to pull that thing out neither his
shirt or his teeth are going to be nearly that white.
