2020.07.26 "Extra" Pic
kcm.MN
Location
NW Minnesota
puzzle: https://jigex.com/Xhds
I had a 57 Dodge truck with a 392 Hemi with a 871 blower and Lakewood headers on it. Had to put tennis balls in them and my buddies would
push them down in them so I had to crank it over to get them out. It was a straight axle truck and you didn't drive it, you rolled the window
down and herded it down the road.
It is a V8. The wires bundled to the front arent going to another plug, they are going to the angled distributor located there.
(quoted from post at 13:18:07 07/26/20)
The flathead V8 had just 3 exhaust ports on each side.
That's the reason they have such a sweet exhaust sound when equipped with duals and "glasspacks".
That is the famous Ford flathead V-8, used 1932 to 1953. There are only 3 exhaust ports on each side. The center two cylinders both exhaust through the same port. Since the exhaust port goes through the water jacket, these engines had a heating problem that really was never solved, in spite of different water pumps, radiators, and fans. Whenever you pull the head off one of these, you are very likely to find a crack between the two center valve seats, and often down into the cylinder wall. If you could keep them cool, they were a great engine, and extremely quiet - no push rods, no rocker arms. They have made a comeback in recent years - many new and improved parts, and tons of history.
