How to remove lower dash panel on late model 4020
docgrt
Need to remove my lower dash panel on side console 4020. All my other tractors are dash control models and have a bolt to remove where this one just has a slot. Just don’t want to bend or break anything. Thanks, George
I'm going to assume the later [side console] 4020 is like the 2520. Remove the side shield, and there's one 5/16" nut you remove from a stud, then the sides slide off to the rear.
Ditto what Bob stated. Nut requiring removal is key 16
Look carefully kind of hard to see . It will slide off clip 21. It feels like maybe you could just pop it off but you will only break the clip.
