hydraulic question
grizz02
should I worry about using a rental hydraulic auger on my new tractor , my thought is I could dump material into my system if it had something in it , your thoughts thks
If that worried about it remove one end off the hose and connect the other end run it to push the oil out into a pail. Problem pretty much solved.
(quoted from post at 10:56:28 07/08/20) Never heard of a hydrolic driven auger, only PTO
I agree drain digger motor if no oil contamination is desired.
Belltec has been in business located in Belton,Tx for many yrs building hyd powered diggers. They build 3 pt & pendulum PHD's.
