Triticale is cut
SVcummins
And cut one field of prairie hay today. The yellow is clover I planted two years ago there is about that much more that isn’t as mature and some red and purple clover in here .
Also a little alfalfa in the other side of the field that I drilled the second week of December
Got the needles almost in sure Is an easier job with two people I’ll tell you that know making one quarter turn then crawl up the ladder and find need to go an 1/8 of turn check the other way .
Left to right is pretty close now I need to set the distance between the needle and twine discs . Will the twine tend to pull the needle away from the knotter frame ?
