Help with my B 275
My 1962 B 275 diesel engine cranks but Will not start. Looks like shut off plunger is stuck on off position. Do you know any trick To unblock the plunger without removing or opening fuel pump ??
Not really any shortcut. My concern would be why.
If it's been stored for years, or if there was a mechanical failure, either way you need to know what's going on in there.
Even if it did start working, the next event could be a runaway!
(quoted from post at 10:52:44 07/04/20) Not really any shortcut. My concern would be why.
Thank you for the advice; i agree with you. Aany one has a drawing i could use to work
With? I have a shop manual; but i canot find a drawing or plan of the parts
(reply to post at 15:43:24 07/04/20)
Thank you for the advice. Do you know of any photograph or drawing or exploded view that i could use To avoid mistakes if I open the pump To look at the plunger and endure everything works fine
Thanks again
Thanks again
(quoted from post at 07:48:05 07/04/20) My 1962 B 275 diesel engine cranks but Will not start. Looks like shut off plunger is stuck on off position. Do you know any trick To unblock the plunger without removing or opening fuel pump ??
Went To the barn this afternoon To check my tractor. Big surprise, I had ordered my book from registration papers for a B 275 tractor. But; it looks like it s a B 250...
So; I know there are diffrences. But are these major diffrences?? I Feel little dumb at this point...
