hi all I have a 1155 mf with the 3 pt not moving up or down. I used it to cut some hay until a seal went out of my swather. then hooked the baler up to it and baled for a couple days then my baler broke down. Hired the rest dont and got my swather fixed but when I went to use the 3 pt I had nothing. I opened up both the inspection covers and watched the linkage go through all 3 functions to make sure I could see the servo piston move up and down. I then started up the tractor while watching through the front cover and you can hear hyd pressure up and fluid coming out from the left hand side then it stops. When I shut off tractor you can hear the fluid de pressurized from what it sounds like. Any one have any thoughts i have a manual but its just a copy and is in black and white and can't see any of the pictures very clearly. Thanks for any help
Bart
Bart
