This all started out with a leaking exhaust manifold gasket. When I got the manifold off I noticed that the welch plug behind it was leaking the gasket was holding the coolant in. My question is what does someone use to seal the new plug? The last plug I tried to put in leaked I had a terrible time with it. Should I try a permatex aviation form a gasket, or Indian head gasket shellac compound? This is in a forklift and is not easy at all to remove the exhaust and intake manifold very time consuming and frustrating. The last one I did I gave up on and finally put an expandable plug in. Not an option in this case. I will add this one is going to be a pain to pull out it’s only about a 7/8 diameter and the cup is deep.
