If the drive band is loose, and it still drives, and if the brake band is working and will stop it, but makes the engine load, it has issues in
the PTO unit. It will need to come off, Sorry about that. My way of adjusting the PTO is as follows, but will apply when it is fixed
Band PTO
Here is my take. Look at the linkage and be certain it has no lost motion, there are pins and woodruff keys in the system that can be loose.
Fix if found.
Place the lever 1/2 the way between the latching points of on (up) and off (down).
Remove the little dome cover on the PTO box. Under this will be two lock nuts and two adjusting screws.
The PTO should turn by hand (engine off).
Loosen the lock nut, and turn the front screw in until you can feel the shaft start to resist turning by hand. Loosen it just until it will
turn free, no more.
Do the same for the rear adjuster so that it can rotate free, but no more.
The front adjustment is the drive adjust, the rear is the brake adjust.
If the screws are down level with the adjustment lock nut top, the bands are worn, and will need replacing, or relining at a clutch shop. That
is not quite the book way, but I have used it many times. Jim
Exploded view.
