newhollandnut
I know this isn’t really tractor or classic related but I thought I
would check the brain trust on here. I have a 1997 1780 12/23
conservation till and this week is has started going a little
nuts. Some times when I turn on the end row and start to put
the planter in the ground it starts to fold up on me and I have
to stop switch to transport mode and unfold the planter to get
the lock hooks to catch on the sliding frame. I have tightened
the hook adjustment rod as tight as it will go and it is still
doing it. Tonight it was only doing it on the north end of the
field and with turning and trying to find my marker and get the
planter back in the ground I can’t see what exactly is going on
for sure and it doesn’t do it every time and seems to be worse
right after I’ve unfolded and began planting. After a while it will
stop trying to fold. It only does it as I drop the planter back into
the ground. Everything seems to be working fine it folds and
unfolds as normal I’m just getting 8-10 unexpected fold ups
per field. Does anyone have any experience with this?
