what would you do? I have a hydraulic cylinder that is driving me nuts. It retains so much back pressure in it that /i cannot hook the hoses up to the tractors outlets. most if not all other cylinders I can press the hose tips against something solid and "bleed" or release some fluid which will allow me to hook up the cylinder hoses to the tractor. This cylinder will not cooperate and I cant get the tips to bleed fluid out no matter how much I bang them against a drawbar or what not. I have resorted to unscrewing the hose fitting at the cylinder to bleed off some pressure. Any suggestion? Is there a bleeder valve I need to install or even something simpler?
