My Hybeams would overheat the switch and blow the built in fuse. So I changed the hi-beams to LED hi beams. Worked great last year. This year the Hibeams wouldn't stay on. If you wiggle the switch, they might come back on for a time, then go off. So to fix that I put new Hibeam LEDs on the low beam side. I also installed an A&I light switch. I didn't like the in line fuses they had on the light switch so I found a 10 ga in line fuse link. So now the Hi beam LED's Don't come on until you wiggle the switch. 2nd question, the low beams had 3 wires. white black and red. I used the red and black to connect the LED's. Would that have any affect? Are the A&I switches bad? Thanks
