I am newer when it comes to working solo on tractors. The sediment bowl on my F20 looks like it isn't full of fuel because I see liquid and then particles floating maybe half an inch from the bottom of the bowl and nothing above it. I read somewhere online that it could mean the bottom part where I only see the liquid could be water but then the gas is above that? Should I turn the gas off and remove the sediment to clean it out? I plan to remove the gas tank this winter and seal it from the inside because the particles I believe are rust pieces. I had a pinhole leak that I fixed from the exterior by using Seal All so it's fine for the summer is the plan.
Thanks for the help!
