30U Plymouth
New User
Hello everyone, I recently purchased my first tractor. It is a Ford 3600.
Can anyone tell me anything about it?
Stamped on the side of tractor near rear axle is
D 5 NN 7008 N
Stamped on the side of tractor near the starter is
D5NN6015F
Does this mean that someone built my tractor using parts from two tractors?
It also has a leaking axle on the right rear that I need to repair. After I jacked up & removed the tire...I noticed that the axle had a lot of movement in & out.
After removing the axle, the seal and bearing looks good but it appears that the bearing isn't setting to the bearing race all the way.
NOTE: There is a large nut behind the bearing. Is it possible that it needs tightening?
D 5 NN 7008 N
D5NN6015F
