randy1
I live in western pa needed 3 simple banjo bolts for a injector pump none of dealers around me stocked them or could even tell me the size. but I noticed the 4 that I called had all been bought out changed their names . none where called john deere .. land pride ect
It's necessary to know tractor model &/or inj pump brand/model for one to give a correct answer. I just guessed at tractor model & bolt for inj line to fit Roosamaster IP on 4020 is R26726. You can order online at Green parts store.
https://www.greenpartstore.com/John-Deere-Hollow-Screw-R26726.html
That is a part that is rarely ever sold. They can not stock everything. I doubt that CaseIH or AGCO would stock them either. Yes it is frustrating at times but understand the dealers point of view as well as it cost to stock parts that do not sell. Tom
You're looking for an injection pump part, not a tractor part. Need to know the pump make and model number to get the correct bolt, some have a valve inside, and some don't. Most are 3/8 NF thread. Check with a diesel repair shop and have the pump info numbers on hand.
I made one once in a pinch. Matched the old one up to a regular bolt and then put it in the lathe and bored a hole into it and then cross drilled it in the drill press. Got me by until I got the proper one.
I made one, too. Used a piece of brass barstock and
drilled and tapped the side to make it non-metric to
attach a fuel line. Worked great.
