(quoted from post at 20:54:59 05/02/20) So I'm trying something on a 12v VR.
Friend that is helping me is asking what
the max field current would be. Since I'm
here, I had no idea what the value would
be. While I'm asking, what would a 6V VR
have for Max field current?
Thanks.
ore out's Deere numbers are good typical numbers! Seen similar range for generators in size from 15 amp output up to 50 amp output.(quoted from post at 01:48:14 05/03/20)(quoted from post at 20:54:59 05/02/20) So I'm trying something on a 12v VR.
Thanks.
That's a pretty VAGUE question as you didn't tell us what you are playing with, or even the make and capacity of the charging system, but, what the heck, I'll play!
To start with, here's some DEERE 4010 and 4020 generator specifications:
(quoted from post at 03:19:18 05/04/20) > However in seeing the 4020 results down below, so I'm pretty sure anything older would have less due to not being as advanced.
Actually, no. Those values were for 12 and 24 volt generators, but you have a six volt generator. Note that the field current of the 12 volt generator is double that of the 24 volt unit.
