I am working on neighbors 2950 with cab. The hydraulic clutch stopped working so I opened the bleed on the slave cyl to see if it had air in the system. No air and no pressure. I put a new clutch master cyl on, bleed the system and still no clutch and no pressure. There is a 1/8 line from the slave cyl to the bleed on the Hi Lo trans. Opened that bleed and got plenty of hyd oil but no pressure. I am more than sure I have all the air out of the system. If the slave cyl was bad I should see some leakage but I do not see any. But I do not know where the hyd oil goes on that HI Lo system. Could I be losing pressure somewhere on the HI LO and how do I determine I do or do not. My IT shop manual says to bleed the HI LO bleeder but says no more about it. It doesn't even show anything about the HI Lo and I do not want to start ripping into things without having an idea what I am doing. Can I simply plug the line going to the Hi Lo and get the tractor working just to get the corn planted. I don't care if the HI Lo doesn't work just to finish the corn. Any info will be appreciated.
