john deere 301A rear hydraulic
levitran101
New User
I'm a newbie, please help. I just bought a deere 301A diesel. I have only one power beyond line from the pump to the rear that powered the pto, and a T from this line that powered the power steering. How do I add rear hydraulic to use a backhoe? My backhoe has 2 quick connect hose. Please be specific on parts needed.
Welcome to YT
My knowledge of JD industrial tractors is limited so I might not be correct. Below is a photo a parts photo showing pressure line(hose item 13) attached to pressure control valve located on lower RH side of trans case & return oil hose(item 14) routed to hyd filter via attaching to hyd filter housing.
Is this the valve you mentioned? The arrow is the end of the pressure line that runs directly from the pump.
If this is the valve, what is the purpose of nut/bolt on the other arrow?
At the inner rear of right side foot rest. One should check with engine idling. Oil is correct level when at full mark with nut of dipstick is resting on tube.
